Sponsored by: CARiD
clutch decision help please
Old Sep 27, 2008 | 06:53 PM
08s2000CRbackinblack's Avatar
Default clutch decision help please
i was looking on competetion clutches' website and they dont show anything for the 08. i am assuming the 06 kit will work on the 08's, right?
Ceramic clutches better than the iron clutches?
any ways i cant decide an which clutch kit to get, i want it to be able to hold around 500 hp with out slip. please give me any opinions an which kit would be more reliable and not be as harsh on my trans while still supporting the hp. i dont want to have to worry about crank walk, would the Ironman clutch kit hold
500hp, or should i go with the Stage 4? any input is greatly appreciated
IronMan Street/Strip Series 1680 Clutch Kit
This assembly features our advanced hybrid iron and carbon friction material riveted to our high torque disc assembly in a six puck style. The IronMan provides outstanding stability, smooth engagement, and less wear on opposing surfaces. Offers 175% increase in torque capacity.
The 1680 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Iron/Carbon buttons, all applicable bearings, and the appropriate alignment tool.
OR
Stage 4 - Strip Series 1620 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity.
The 1620 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
Old Sep 28, 2008 | 03:21 AM
+bump
Old Sep 28, 2008 | 05:16 AM
main question -will a 06 2.2L clutch kit work for the 08? i would think so, but want to make sure before i buy it
Old Sep 28, 2008 | 05:28 AM
istdercollen's Avatar
yes 08 =06 but you didn't say anything bout your mods.. you don't need a puck disc clutch if you don't have the rest of your drivetrain beefed up, you'll just break something. .02
Old Sep 28, 2008 | 05:56 AM
SgtB's Avatar
You also need to choose a clutch based on your torque output.
Old Sep 28, 2008 | 08:32 AM
what drivetrain components would be the first to go after upgrading to a 6-puck disk? i only have intake and exhaust now but am goin turbo soon and the clutch is gonna be the first thing i buy for the build. would you suggest this over setup over the 6-puck? i just dont want the clutch to be slipping at 500hp. i wanna get the clutch i will need the first time, please give opinions
ALternative to 6-puck?
Stage 3 - Street/Strip Series 2300 Clutch Kit
This segmented Carbon Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up
Old Sep 28, 2008 | 09:22 AM
CROD's Avatar
i have the comp clutch stage 2 in my 08 CR
Old Sep 28, 2008 | 10:33 AM
what in the driveline would break from using a 6-puck? wouldnt it be the torque of the engine of a turboed car be the cause of something breaking or the harshness of a 6-puck clutch?
Old Sep 28, 2008 | 11:43 AM
PrOsPeCt S's Avatar
this is what i put in my 07, Toda flywheel, ACT HD PP,OEM Clutch Disc. and removed the clutch delay valve. and works great.
Old Sep 28, 2008 | 12:58 PM
why would the 6-puck break things? torque is the enemy of weak parts right?
