Sponsored by: CARiD
clutchmaster good? or bad? HELP
Old Feb 16, 2010 | 04:20 PM
bogii's Avatar
Default clutchmaster good? or bad? HELP
http://cgi.ebay.com/ebaymotors/00-08-HONDA...sQ5fAccessories
Ive heard bad things about puck style clutches
Im pretty hard on the car
great price as it comes with the flywheel
this is not spam i need a clutch any opinions???
Thanks Bogart
Old Feb 16, 2010 | 04:34 PM
KchaoS2K's Avatar
first off that is E clutch master which is no where near the quality of real clutch master clutches..in my experience i have had pretty good luck with clutch master clutches(non generic) in other cars. so to answer your questions yes clutch masters(non generic) clutches are pretty good..
Old Feb 16, 2010 | 05:01 PM
ahrmike's Avatar
Because a eCLUTCHMASTER Liteweight Racing Flywheel® has so much less rotating inertia than the stock 20-30lb stock heavy flywheel., it is easier on your synchros. When you downshift and do not perfectly equalize revs, your synchros must accommodate the difference in flywheel speed and input transmission speed. The lighter the flywheel the less the inertia the synchros must overcome. The longer your synchros last the longer your tranny will last because you are less likely to miss-shift and break things when your synchros are properly functioning
lol, sort of on the wrong side of the transmission unless you're no clutch shifting...lmao!
Old Feb 17, 2010 | 10:33 AM
bogii's Avatar
so the ebay clutchmaster is a chinese knock off???
ForkYou
Aug 18, 2011 08:12 AM
PersianSTud
Feb 18, 2011 05:01 PM
jtazz1966
Feb 15, 2009 12:10 PM
Nick32
May 5, 2005 03:36 AM
