Coilovers Question
Coilovers Question
Hi, Im interested in coilovers is there one which the height, bump & rebound settings can be adjusted throu a control unit which can be mounted on the dash?
rather then removing each rim to change the settings?
thanks
thanks
lol yea apart from airbag suspension i dont believe such a "coilover" exists.
you can however get electronic damper controls for tein coilovers where you can set damper from inside the car.
Tein flex with the EFDC unit will allow you to adjust dampening from the cabin.
The only way to get height adjustment from inside is an air ride/air bag suspension.
