cooling plates
Ok I searched and could not find the exact info I wanted. The search feature is not working so well either, I used Google to.
Ok so lets discuss some cooling plates... Do they work? I think the AUT works with the FIPK correct? Will it also work with the stock air box?
I am a new owner but I get the Idea that mods dont do much for what they cost for the S. Anyways, I do like way cooling plates look, I just dont want something that does not have a positive purpouse. From what I read you also have to remove some of the plastic shileding to install a cooling plate. If Honda has desinged this car so well, I dont want to remove something and add a cooling plate if it's not good.
I was thinking that maybe I would buy a FIPK but I am not sure, obviously it is more for sound. Thanks for the help....
Chris
Chris
the whole point is to just direct air into the radiator. stock one is fine. I just liked the look of aluminum. most aftermarket ones have a vent near the airbox location to allow more air through, but if u don't have the factory airbox it's actually better to get a flat cover. more air to the radiator.
Good post. They do work.... just as good as the stock one
