Sponsored by: CARiD
CR Wing
Old Feb 17, 2009 | 02:59 PM
Olegator's Avatar
you need to mod the trunk in order for the CR wing to fit properly
Old Feb 17, 2009 | 06:06 PM
silentdancer's Avatar
Originally Posted by dparm,Feb 17 2009, 07:10 AM
What's an AP1 spoiler?
Old Feb 18, 2009 | 01:47 AM
Ks320's Avatar
What do you mean mod the trunk?
I thought you just need to take the trunk to a body shop ... fill the holes and spray over the trunk again
personally I would just do a swap if the conditions of the trunks are similar
Old Feb 18, 2009 | 03:12 AM
Olegator's Avatar
you'll need to insert reinforcements so that the trunk won't flex. Go to the dealership, look at the underside of the CR trunk and fab up something similar. You might even be able to buy those reinforcement parts separately from the dealership....
Old Feb 18, 2009 | 03:14 AM
Olegator's Avatar
I'm not 100% shure wether the reinforcements are the integrated in the trunk or if they are bolt on pieces, so hopefully somebody will back me up.
Old Feb 18, 2009 | 05:49 AM
Ks320's Avatar
? What reinforcement parts are you referring to
I have the CR wing and it doesn't have any reinforcement parts. I only bought the wing + the stands + rubber stubs (to go along the gutter area) + those stiffer trunk springs (which only help to hold the heavier trunk up, and don't do anything to stiffen up the trunk)
The parts list don't suggest there is anything more than the parts that I listed though
Old Feb 18, 2009 | 10:01 AM
RFCR's Avatar
CR trunk is different. There are new mounting points for the CR wing and the trunk has cross bracing. Remember the CR is fully functional aerodynamic component of the CR and works in tandem with the front lower spoiler. Anything less is simply ricer IMO
Old Feb 18, 2009 | 11:02 AM
zdave87's Avatar
Member
[QUOTE=RFCR,Feb 18 2009, 02:01 PM] CR trunk is different.
Old Feb 18, 2009 | 12:51 PM
Olegator's Avatar
actually, if you look closer there is another sheet metal piece in there...
Old Feb 18, 2009 | 12:57 PM
DanZilla's Avatar
