Sponsored by: CARiD
Cusco Catch Can
Old May 24, 2009 | 08:22 PM
Nickamsweet's Avatar
Default Cusco Catch Can
Hey,
Just installed the Cusco oil catch can but haven't connected it up yet since I heard that the hose that originally comes with the can seems to collapse under vacuum?? I bought the 15mm fitting can since in the future I will be FI it so built for the future...
Where is the best place to buy that size hosing and what is the best way to attach the PCV to the larger diameter hose?
Thanks for any help,
Nick
Old May 25, 2009 | 10:17 AM
jarrod_aspden's Avatar
i personally just went to autoozne to get fuel line hose its rated for high temp and works just fine. its really thick wall to and does not collapse at all.
Old May 25, 2009 | 10:58 AM
awesome cheers for the help... did you go with the 9mm or 15mm option for the catch can?? If 15mm did you just use a reducer or something to attach to the 9mm PCV?
Old May 25, 2009 | 04:18 PM
Bob A (SD)'s Avatar
There's a number of good threads on catch can installation located in the Under the Hood area (eg https://www.s2ki.com/forums/index.php?showtopic=270320)
Although mines not a Cusco, the Greddy is basically the same available in 9mm and 15mm flavors. I used red NAPA 3/8" (9.5mm) 1-braid 250 psi multi-duty hose CS082803 Y500 for my installation.
Old May 25, 2009 | 09:09 PM
Olegator's Avatar
usual hoses that come with catch cans do seem to collapse all the time... : /
RobertJohn
Oct 30, 2011 06:11 PM
Colin mc rae
Κινητήρας - Μετάδοση - Περιφερειακά
Oct 28, 2011 04:32 AM
S2000_Europe
Apr 29, 2005 03:44 AM
wantgoback
Mar 27, 2003 12:22 AM
