Custom Heat Shield
The ambient temperature of your engine bay may... not lower as fast (when sitting stationary). However the MAX temp should not be any higher due to this additional pieces of material.
I thought of one other additional piece you could add to this.
- Add weatherstripping to any top edges so it sits flush and seals against the hood.
- I used molding clay to estimate the shape of the hood when it's closed.
El-That rendering is great, thanks man. I like your idea for that lip to stick out towards the engine. I will add it to my prototype tomorrow.
Matt- That's great. Yeah that was my argument to my dad; that cold air will come up from underneath the motor. That's a good idea about the weatherstripping. It's probably a pain in the ass to do. I will try it when I get it back from my dads friend.
Well the hood isn't perfectly flat so I'm not sure if weather stripping will work too well. I will probably just add a 2" lip like you suggested; Least labor intensive and it will probably make it look cleaner (although so would weather stripping). Thanks for the input guys. I will post results as well as dimensions for you to make your own.
