Sponsored by: CARiD
De-Cat
Old Jun 6, 2013 | 09:52 AM
SebbyWebby's Avatar
Default De-Cat
Hi Boys and Girls!
Been a while since ive posted on here as i sold my s2k. However i have just bought another one and want a bit more out of this one without changing it much (UK 2006 2.0L)force induction later down the line but for now i'm looking at removing the cat.
I've been doing a bit of research from the exsisting threads and they were great..learnt a lot. However they have led me to the number of questions i am now about to ask!
1. I've read that i really need a pipe with a device in it to prevent getting CEL..what is cell??? Is it some sort of fault code?
2. If i do de-cat it will i need to re-map the ecu?
3. Also what kind of power gain am i looking to get from removing the cat?
Thanks for your time peeps..look forward to hearing from ya?
Seb
Old Jun 6, 2013 | 02:54 PM
nos4you's Avatar
search "test pipe" you will find lots of answers. Most test pipe do come with de foulers so you don't trip a CEL though.
Old Jun 6, 2013 | 07:57 PM
CoolGuy094's Avatar
Seb,
1.) CEL = Check Engine Light. Yes, it is a fault code. Most test pipes have built-in defoulers, i.e. extended mounting wells that your oxygen sensor screws into. It keeps the sensor further away from the exhaust gasses and prevents the ECU from detecting that there is no longer a cat installed (basically). On 00-05's this works just fine. 06+ mods are more difficult to fool. Hopefully an AP2 owner with test pipe experience can chime in here to help.
2.) No.
3.) 3-5 HP maybe (this will be debated). Test pipes unlock a bigger gain if you are FI, and/or if you have other supporting mods like intake/exhaust that are helping to "free up" the flow.
4.) You have a cool name.
Old Jun 6, 2013 | 08:10 PM
jl56tc's Avatar
my friend just ran an o2 simulator and it seemed to do the trick... Just a thought
Old Jun 7, 2013 | 04:55 AM
Reckon's Avatar
The answers you want are as CoolGuy094 stated.
Search the test pipe thread in the NA subforum for more information:
https://www.s2ki.com/s2000/topic/636...t-pipe-thread/
Old Jun 7, 2013 | 06:04 AM
SebbyWebby's Avatar
Seb,
2.) No.
Thanks Coolguy! Certainly cant be arsed pissing about with the ecu at this point! Just want a quick simple fix to get a few more horse power and this seems like the way. So you suggest maybe getting an induction kit? Shall i get rid of the big air box that the filter is in all together because i can see that being quite restrictive?!
haha Thanks pal
Old Jun 7, 2013 | 06:05 AM
SebbyWebby's Avatar
Thanks recon!
Old Jun 7, 2013 | 06:07 AM
SebbyWebby's Avatar
Hi jl56tc! I'm thinking this is a simulator to trick the ecu thinking the pipe hasnt changed or simply re-calibrating it so it allows the pipe change?
Old Jun 7, 2013 | 06:08 AM
SebbyWebby's Avatar
Thanks for the info nos4you!
Old Jun 7, 2013 | 11:26 AM
spdoran's Avatar
I have an AP2 with the Invidia test pipe w/ CEL fix. It won't fix the CEL as is, but the bung pre-welded onto the test pipe will easily fit one of the T1R CEL fix units to help out. Now, the CEL does blip every now and then for a few days, but it goes off on its own or can be reset by unhooking the battery. The gains are exceptionally good for the price of a test pipe and the sound is much better. Just hang onto your old cat incase you want to or need to go back to stock. Don't worry about a tune.
