Sponsored by: CARiD
Decat
Old Nov 19, 2009 | 01:46 PM
ScoobyWhite's Avatar
Default Decat
Hi
I would like to know if some one here already fit in the decat section one resonator so the car stay a little bit not so loud!!
Thanks
Old Nov 19, 2009 | 02:12 PM
suzuka-blue-s2k's Avatar
Are you talking about getting rid of the cat and replacing it with a test pipe?
Old Nov 19, 2009 | 02:21 PM
nitewing117's Avatar
Originally Posted by ScoobyWhite,Nov 19 2009, 02:46 PM
Hi
Thanks
there's a resonated test pipe that you can buy....if that's what youre asking.
Old Nov 19, 2009 | 04:15 PM
bigmacnfries's Avatar
do you mean a hi-flow catalytic converter, or a test pipe? there are heaps of threads on both... search and ye shall find.
if it's neither of those, then..... what?
Old Nov 20, 2009 | 09:44 AM
Mike21's Avatar
sounds like you want a resonated test pipe.
Old Nov 20, 2009 | 11:05 AM
Thanks for your help and interest
I want a test pipe with a resonator but something that really does not restrict but that get the DB value a little bit lower!!
Thanks
Old Nov 20, 2009 | 04:01 PM
Moddiction's Avatar
Former Sponsor
Test pipes make the car louder if you have a cat in the car now.
If you have a non resonator test pipe than just pick up a resonated one and it will quite it down a little bit.
Old Nov 20, 2009 | 05:21 PM
Nyther's Avatar
T1R makes a resonated testpipe but the resonator isnt filled with anything.. just empty space so it's still loud..
Im cutting the resonator soon, putting in some sound dampening material inside the resonator and re-weld it back to get th DB's down
Old Nov 20, 2009 | 09:08 PM
ap1_tot's Avatar
^^ nothing inside the resonator? why would T1R do that?
Old Nov 20, 2009 | 11:24 PM
iam7head's Avatar
I am not sure what exactly is in this case but it could be one of the following
1)fiber material burnt/blew away: typical result of low end "glass pack" resonator
2)chambered design: direct air flow to muffler the noise, lots of OE applicator and older muscle car resonator are build this way, not very likely to be in this case
3) straight thru design: nothing "in" the path of the gas flow but there's an exposed chamber with perforated screen on the sidewall.
