Depo tail lights Hyper flash
Old 08-15-2018, 10:16 AM
Sponsor
JS2k.com's Avatar
Originally Posted by maxl
Sorry if im just not understanding, but the plug and play harness does not appear to fit into the depo turn signal plug by looking at the picture on the website? I am currently using my OEM harness which is plugged into the depo tails (all of them fit but it hyperblinks)
Sorry, my mistake. The plug and play harness may not fit the Depo Turn Signal Light plug. They were designed to replace the factory bulb socket. You'll need the ones to splice into your wiring. http://www.js2k.com/index.php?main_p...roducts_id=166
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old 08-15-2018, 02:42 PM
maxl's Avatar
ahh ic. Thanks ill look into it some more! Bought all my leds and ap1 clear diffuser off your website recently too btw
Old 08-15-2018, 07:46 PM
Sponsor
JS2k.com's Avatar
Thank you for your business!
Old 04-21-2019, 02:44 PM
Cpt. Spock's Avatar
Did you ever figure this out? I currently have the same exact issue.
Old 04-22-2019, 06:18 AM
Sponsor
JS2k.com's Avatar
These will fix your hyperblinking for the Depo tails.
Turn Signal LED HyperBlink Fixers - $4.00 : JS2K.com!
__________________
_________
Cpt. Spock (04-22-2019)
Old 04-22-2019, 09:13 AM
Cpt. Spock's Avatar
thanks for the response. Do you have instructions with your kit on how to splice them into the wiring?
Old 04-22-2019, 09:14 AM
licelsior's Avatar
I had them on my car and they never hyperblinked unless if i had a LED turn signal up front.
Old 04-22-2019, 09:18 AM
Cpt. Spock's Avatar
i have led parking lights up front, not led front turn signals. I do have led side marker lights though.
Old 04-22-2019, 06:37 PM
Sponsor
JS2k.com's Avatar
It's pretty simple. The kit includes T Taps, so you'll place the T Taps on one end of the resistor and put the T Tap on one wire of the turn signals and crimp them down. Repeat with the other side of the resistor and crimp them onto the other wire to the turn signals.
__________________
_________
Sponsor
JS2k.com's Avatar
Only changing the front or rear turn signals will trigger hyperblink. Not the sidemarkers nor parking lights.
__________________
_________
Quick Reply: Depo tail lights Hyper flash
