Diff Mod... I want it bulletproof.
Thinking of doing a diff upgrade next now that I am turbo'd and am considering either the Inline diff conversion kit OR the PuddyMod built diff... what do you all think? Comments please.
Thanks
Thanks
Well, as far as price goes, I believe the PuddyMod built differential costs less.
From what I understand, they will both handle a lot of abuse.
Originally Posted by S2KPUDDYDAD
The diff caps will hold at most anything an S2000 engine can toss it's way. You maybe able to brake a housing or LSD but, the caps will hold thumbsup.gif
Like it's been said nothing is 100% bulletproof but it is unlikely you will brake the PuddyMod rear.
The r200 diff swap from inline can get a little exspensive, there kit does not include a diff. you will have to find one at a junk yard ( 90-96 300zx NON turbo with ABS) not to hard to find but you should have the diff checked out befor install.......
Inline Install kit (1000 hp axels) 2900+shipping
R200 diff 100-400 depending on junk yard and cost of having it checked out....
This diff has a 4.09 ratio and i'm not to sure of the avalible ratios....
If your planing on making on huge power go with this set up
The puddymod is also a great diff...... Ideal for N/A and FI up to 500, but this retaians your stock driveshaft and axels which have their limitations
Much better price
Much better price
Much better price
Much better price
Originally Posted by SPECIAL-OPS-S2K,Mar 16 2008, 12:17 AM
so if I went puddymod and upgraded my driveshaft and axles then it would be even better... correct? I am FI turbo'd and should be putting down in the ballpark of 500-550whp once I'm all tuned and setup properly... would a puddymod and upgraded axles/driveshaft handle this power without failing? With the occasional launch in there?
Also FWIW, IP has a 600hp R200 diff kit for around 2500ish I believe.
Originally Posted by Spec_Ops2087,Mar 15 2008, 10:15 PM
Correct me if I'm wrong but after you upgrade your axles and driveshaft ALONG with the puddymod diff, your right in the inlinepro 1000hp cost territory at which point it makes sense to get the beefier diff anyway.
Thanks for your input, any others?
Originally Posted by killerbee_vr6,Mar 15 2008, 11:19 PM
remember, kids, strengthening the weak point only moves the fuse.
