differential collar
Have you ever tried hammering a nail into a board that you are just holding in your hands? Since your hands aren't rigid, the force of the nail simply causes the board to move, and the nail will not penetrate. The only way for the nail to actually penetrate is if the board is held rigid. In the case of the diff or transmission, the rubber mounts allow the vibration energy to pass through the bearings to the casing and rubber mounts. However, if you make the mounts rigid, the energy will stay between the moving parts, which will increase wear.
I have the EVS red collars on my ap1. i bought the car and was changing out the diff fluid when i noticed the collars.
my car vibrates like a motherf#$% on the highway. anything above 75 and its vibration city.
anyone think its the mounts causing the vibrations? and what the hell do these things even do?!
Throttle response. ^ i have a stage two puddydad in it so im not worried about wear on the diff but i am if its stress on the tranny. Ive gone all the way back to stock and then installed the collars and it still vibrates so this must have always been there just never noticed it till i installed them. Though when i take out the forward small collars it goes away with the back bigger collars still in and those 4 are really what increases the feeling of response because they dont allow the diff to twist so vincefriday you could try doing that. Im gonna try doing it and ill let you know if it cuts down on driveshaft vibration. Should have bought my s brand new "smh" i got mine with 20k on it.
Originally Posted by steamedturtle' timestamp='1343052716' post='21881539
I can't visualize any way that they significantly or otherwise reduce the life of your diff or transmission.
