Sponsored by: CARiD
DIY bat relocation
Old Oct 15, 2016 | 04:26 PM
MorngWoodStewie's Avatar
Default DIY bat relocation
My bat relocation DIY
Take your bat tray and bolt it to the donut hole same bolt thread and pitch. If your really cool you could somehow either self tap the other to but I use 3m Velcro on the other side and tightened the main bolt well.
Attach your grounds I'll upload a finished pic, once I go get a 100 amp fuse. I had to use a fused terminal in between cause my 0 ga was to short
Front area connect your 0ga somehow via terminal, solder et.
Empty hole needs cleaning
Old Oct 15, 2016 | 04:29 PM
I did the relocation first cause it would not make sense to do the SOS re wire kit until it was relocated.
Old Oct 15, 2016 | 04:31 PM
Lol dont ask about my donut did not come with one!
Old Oct 15, 2016 | 04:40 PM
I stalled and started SOS wire kit
Old Oct 15, 2016 | 04:41 PM
Not much more to see
Easy an quick.
Old Oct 15, 2016 | 05:38 PM
windhund116's Avatar
Just a suggestion. If you still can, you may want to put HD insulator shrink wrap over those butt-splice connectors. Helps keep the contact tight & moisture out.
Old Oct 15, 2016 | 06:18 PM
Thanks will do. I was actually working on the other end lol. Actually skipped right over that one
Old Oct 15, 2016 | 10:02 PM
So because my 4 or 0 gauge can't really tell was to short I had to put a 100amp fuse inbetween.
Now the starting seems weaker.
Volts are good it's charging and all, I literally just did this so my question is could the extra fuse have some extra resistance? Or should it all just be straight 0 ga?
What I bought from auto parts store I thought was 0 ga but when I went to audio shop there 0ga is way thicker then what I got.
Suggestions? Tips? It's still starting but it's taking an extra crank and lights are dimming to the crank revolution now.
Old Oct 15, 2016 | 10:07 PM
Or should I upgrade the battery or maybe my bat is getting rdy to shit, it has always seemed a lil weak and don't know when it was installed anyways.
Old Oct 16, 2016 | 12:22 AM
Just a quick update after the first three starts its acting normal now again so Idk. Not an emergency I guess or something is super wrong but it is starting like before so
