Sponsored by: CARiD
do i need a camber kit
Old Nov 20, 2009 | 09:49 AM
Tylersp's Avatar
Default do i need a camber kit
Ok so I've been reading around for a little bit and have really not come to any conclusion. So here's the thing, I'm getting a set of buddy club n+ coils and was wondering if I need to buy a camber kit since I know the camber gets screwed up when you drop a car. I saw on one post that you can adust the camber already by some bolt in the rear. Is this right? If so is it the same way for the front? Thanks for any help on this sence I have a really foggy look on this
Old Nov 20, 2009 | 09:56 AM
RogerHinga's Avatar
nah you dont..
Old Nov 20, 2009 | 10:07 AM
h1gh0ct4n3's Avatar
The s2000 can adjust camber, toe, and caster straight from the factory.
But when you lower it even the OEM adjustment will not be enough to keep it into a reasonable spec.
Im in a MY05 and its about half a finger gap all around and my rear camber is excessive even with max OEM adjustment.
So if you want to run a normal camber set up then yes you should think about the rear anti bump steer kit.
The front can adjust fin its just the rear that gets thrown out severely.
Old Nov 20, 2009 | 11:07 AM
ScoobyWhite's Avatar
And where can we found it??
(sorry for the rockie questions )
Thanks
Old Nov 20, 2009 | 11:42 AM
Tylersp's Avatar
Thanks guys for the info so what does this rear anti bump steer kit exactly do
Old Nov 22, 2009 | 07:57 AM
I already see that spoon have a zero bump steer kit for the front and rear...
The rear kit is far difference that the t1r kit! Can you help me and show me the differences??
The rear spoon kit also can adjust everything??
Thanks
jdmsti23
Feb 5, 2013 09:12 PM
s2kroley954
Apr 23, 2012 07:12 AM
s2kone.
May 21, 2010 04:03 PM
s2guru
Apr 13, 2009 01:31 PM
solomon
Oct 7, 2005 01:37 PM
