Sponsored by: CARiD
DOT 5.1 brake fluid
Old Dec 19, 2014 | 05:44 PM
jean-roch's Avatar
Default DOT 5.1 brake fluid
I plan to replace my brake & clutch fluid with DOT 5.1, anywone have do it and can give feedback?
Old Dec 20, 2014 | 12:37 AM
gptoyz's Avatar
I don't know anyone using 5.1; the wet/dry boiling point of high performance dot 4 fluids (motul RBF 600, 660; endless; project mu; stoptech 600; brembo; castrol LCF; torque RT700; maxima racing, etc etc) are all higher than every 5.1 I am aware of.
The clutch fluid does not get hot enough to warrant the use of even high performance dot 4s mentioned above, definitely overkill. For the clutch, you will want a long lasting fluid as opposed to an ultra high wet/dry boiling point.
what are you trying to solve exactly with the 5.1?
Old Dec 20, 2014 | 08:27 AM
jean-roch's Avatar
I will use it (DOT 5.1) on my Yamaha FZ-09 bike as Gulf recommand it to me to have a better and more precise brake feel and feedback.
From what i read, DOT 5.1 was thinner and give a better feedback, the reason it was used on abs brakes system to help the abs pump to react quickly and i dont know if it can give a better brake & clutch feel on the S2KI, i've always run with Wilwood 570 & i have braided brake lines, im very happy with my set-up, simply search to upgrade a little bit!
Old Dec 20, 2014 | 08:49 AM
noodels's Avatar
Got this in the clutch,just absorbs water much quicker so needs more frequent changes they say.
<not a problem for me,has great clutch now,No crunching cold or hot>
its been in 9months and still fine.
When its dirty i will change it..
Old Dec 21, 2014 | 11:41 AM
Car Analogy's Avatar
I would be wary of using it in brakes. ABS was calibrated using DOT 4. The use of 5.1 may cause issues.
05thumper
Apr 2, 2012 02:41 AM
Erriseehuang
Aug 11, 2011 09:30 PM
S2kRally
Sep 24, 2010 04:23 AM
TunedS2000
Jan 16, 2005 10:38 PM
