Sponsored by: CARiD
EDFC
Old Oct 30, 2008 | 04:16 AM
run115's Avatar
Default EDFC
I have a dual EDFC setup, and am trying to fit it to my dashboard just under the steering wheel on the left side, (RHD Car). Problem is I tried various double sided tapes but they keep coming off, any ideas what I can use? I was thinking to use the special silicon from Wurth, whats your thoughts?
Thanks for your help.
Vince
Old Oct 30, 2008 | 07:16 AM
jettfiery's Avatar
have you used any type of protectant on the plastic? Most 3m double sided tape should fit fine IF you get rid of any residual protectant on the plastic.
Old Oct 30, 2008 | 07:25 AM
nightcrawler7188's Avatar
i say make it clean and put it in the tray behind the cupholder. it can fit perfectly in there.
Old Oct 30, 2008 | 08:08 AM
s2kobsession's Avatar
I drilled two holes in the dash and ziptied it on there ahah. Can't even tell the holes are there they are so small, and they are on the bottom of the dash so you have to stick your head at the pedals and look up to see them.
Old Oct 30, 2008 | 11:51 AM
run115's Avatar
Thanks for the input guys, will try something new over the weekend then.
Old Oct 30, 2008 | 12:48 PM
tenaciousFD's Avatar
Clean that contact areas well and use the 3M adhesive promoter/primer made for their double sided automotive tapes. That stuff works wonders.
Headchef
Feb 14, 2016 04:01 PM
metros
Jul 25, 2011 02:09 PM
Munnerlyn
Sep 20, 2009 11:01 AM
jaehoppa
May 22, 2007 07:29 AM
Luvs2Rev
Oct 18, 2004 05:33 PM
