Engine Bay Mods
Through experimenting I have relocated some items that are pretty easy DIY mods.
See pics:
A short 18 oz Weapons-R catch can with cap modded to fit OEM fill tube
Vacuum pump relocated under cowling. Eliminates all metal tubing and unsightly mounting brackets
The EPS fuse box has ONLY 3 wires to extend after relocating the large harness
Cruise control mounted where EPS was located
Comments are welcome.
See pics:
Hi Retvet,
I assume the ret vet means Retired Veteran. Cool!!!!!! I retired (1SG) in 96, after 24 years of US Army.
The damper mount was the original from NRG, which I DID NOT want to cut a hole in the heat shield. So, I mounted it with rubber mounts as you can see in the pics.
Thanks for the service.
EagleDon
EagleDon
