Sponsored by: CARiD
Engine knock / pinking with Mugen ECU!
Old Feb 8, 2011 | 09:34 PM
  #21
banflu's Avatar
Yes you're right.
I will try to bleed it again this Saturday.
I'll try the nose-up method this time.
Re plugs, I just bought the iridium 1-step-colder ones from eBay, hopefully they'll be here by Saturday; I'll replace them and I'll check what the old ones look like.
Old Feb 8, 2011 | 09:46 PM
  #22
banflu's Avatar
Ps: this is what they looked like about a year ago, when I bought it:
https://www.s2ki.com/forums/index.php?showt...&#entry18408872
The pics are at the bottom of the thread.
And yes, it still takes about two seconds to start.
Old Feb 8, 2011 | 11:25 PM
  #23
H22toF20's Avatar
Pictures of your plugs from a year ago, have nothing to do with the way they'd look right now. Have you even pulled them after this happened?
Old Feb 9, 2011 | 01:44 AM
  #24
banflu's Avatar
[QUOTE=H22toF20,Feb 9 2011, 12:25 AM]Pictures of your plugs from a year ago, have nothing to do with the way they'd look right now.
Old Feb 9, 2011 | 01:46 AM
  #25
Sideways's Avatar
Those plugs look fine.
Just add a gallon of race gas to each tankful and the low speed pinging will go away. That's what I did.
Old Feb 9, 2011 | 01:52 AM
  #26
banflu's Avatar
oh, and i did find techron at the local chevron agent ...
just one problem ..
he only had ONE last bottle of it. he said that the Techron concentrate is now phased out, and they changed the name to Texaco Havoline Gasoline fuel system cleaner.
Is this true?
I bought the techron concentrate and one of these texaco thingies.
Uploaded with ImageShack.us
On the texaco one, it just says to pour it into the fuel tank.
On the techron concentrate, it says to pour it into an empty tank, and fill up the tank with petrol.
But on the last bottle i used (fuchs), it recommended to be used with a near-empty tank of petrol, so that it would be highly concentrated.
what is the best way to use this?
Old Feb 9, 2011 | 03:16 AM
  #27
banflu's Avatar
and just one last thing. i am currently using the silkolene octane booster.
its not a problem adding this fuel system cleaner to it, right?
Old Feb 9, 2011 | 02:26 PM
  #28
H22toF20's Avatar
Plugs look fine to me.
Old Feb 9, 2011 | 03:39 PM
  #29
banflu's Avatar
mmm ok. but i had already bought the BKR8EIX, they're on the way. Will I still benefit from using them?
And can anyone confirm that the techron is best used as described?
ie. pour it all in an empty tank, then fill tank with fuel, then use fuel?
or should i fill up just half of the tank? or a quarter? to have it really concentrated?
thanks
Old Feb 9, 2011 | 04:00 PM
  #30
Gernby's Avatar
Former Sponsor
You should still install the colder plugs. Use the Techron as directed on the bottle. Just don't exceed the amount of fuel that it says it will treat. I like to buy the bottles that say "Treats up to 20 gallons", then I use it for my 13 gallon tank. Then I will do the same for the next fillup.
