Engine knock / pinking with Mugen ECU!
i will use this "12-gallon-techron" with around 8 gallons then.
and will use the other one with another 8 gallons.
hopefully it will make a differnce to the engine... if so, i will start to use a bottle or two every year or so.
i'm also going to look into the race gas... i found someone who stocks Sunoco 260 GT Plus (109 RON / 99 MON). I'm planning on buying a 25-litre drum, and try adding 1 litre to every full tank of gas.
I'm thinking, one litre of 109-RON race gas will be more effective than half a litre of octane booster.
But I will try it out and time will tell.
I just now saw your pictures, and noticed that you have the smaller Techron bottle. I guess I'd probably add it to the tank, but only fill it 3/4 the way up.
Your plugs look okay to me, but I'm not experienced at reading plugs. However, I firmly believe it's best to run the coldest plug that you can get away with. There's definitely no benefit to run a plug that's any hotter than "hot enough".
I do think that the pro-boost makes a difference, because i used to add a third of a litre with every tank, and I Used to hear knock.
Then I started to add half a liter with every tank. And knock has decreased.
Knock, as explained, was very very pronounced when I removed part of the air intake.
Today, I re-installed the plugs and fitted the air intake as well.
I also put the techron concentrate in the fuel tank.
I took it for a quick spin, and the obvious pinking has disappeared.
However, upon close listening, I think that there is still pinking going on.
It's just that it's not very audible with the intake on.
So I'm looking forward to receive the new plugs to see of that fixes a part of the problem at least.
I'm also hoping that the techron will make a difference
To be honest, even though I have no experience in these problems, I believe what you say is true.
If i don't find time this week, surely next week i will check about the sunocu racing fuel. I will experiment with adding 1 or 2 liters per tankful.
So I'm wondering.. What difference will the one-step-colder plug do?
Originally Posted by Sideways,Feb 10 2011, 12:33 PM
It will make no difference. Your car is not pinging from hot plugs.
