Engine stumbling after test pipe install
I just installed the invidia v4 exhaust with a 70mm test pipe with the built in CEl fix. Well shortly after installing it the CEL came on so this test pipe does not correct the CEL. I put in 2 non foulers and went out again. I dont have a CEL yet but the problem i'm havin is when i'm sitting at a red light or at a stop, when i press the gas and RPM's go up as soon as they start dropping they just keep going until about 1 bar on the RPM meter is showing. The car shakes like hell and will regain itsself and idel fine. It only does it when i press the gas and let off. I press the gas, let of, the RPM's drop and go all the way to 1 bar on the meter, car stumbles and then regains after shaking violently. Anyone know what could be wrong? Possible idle air control valve? Maybe need an idle air re-learn? And also the car doesnt do it with the A/C on also.
Originally Posted by gotswap,Jun 5 2008, 03:09 PM
Could be that you just need to reset your ecu and let it "relearn"
I don't know what the problem is though, others will chime in.
