Sponsored by: CARiD
Engine Torque Damper adjustment
Old Jun 12, 2020 | 04:01 PM
randomwalk101's Avatar
Default Engine Torque Damper adjustment
Just installed the Silk Road ETD (Thanks Kyle). How a quick question on how to set it as all the instruction is in Japnanese.
The smaller outer nut is a lock nut for the length adjustmebt ...got that. But what is that bigger (inner) lock nut is for? Do I tighten that as well?
is there a light/heavy damping adjustment or is it just one setting? Thanks guys.
Old Jun 12, 2020 | 04:35 PM
Orjinal's Avatar
The bigger one on the left is also a lock nut.
The way I set mine up was by making both the outer and the inner adjustments even in how many threads they're locked in to distribute the load evenly.
Old Jun 12, 2020 | 04:49 PM
Thanks Orjinal...but what do you mean by "inner and outer adjustment" ?
Old Jun 12, 2020 | 05:10 PM
https://images.carid.com/ingalls-eng...structions.pdf
I found the Ingall instruction @ link above. I am guessing it's the same thing for Silk Road ETD.... Finger crossed.. LOL
Old Jun 12, 2020 | 08:38 PM
Deckoz's Avatar
Most dampeners are all the same in regards to the "piston" arm. Ingalls will work just fine for instructions
Old Jun 13, 2020 | 03:25 AM
Kyle's Avatar
Sweet dude! We need more pics of it for science. Literally never saw pics of a silk road damper installed.
Old Jun 15, 2020 | 12:40 PM
Here is a zoom out of it a bit. Also the aftermarket shield doesnt quite fot as good as the stock one...notice it doesnt quite line up on the last tab (the other three are fine). I also had to cut/grind down the bottom part about 1/2" so it won't run on the electrical loom at the bottom. May be bc this was made for jdm market and there isn't that wire there?
I may try to cut a hole in the stock shield and use that instead. Any tip on how to cut a pass through hole in the stock shield (like a template or something)..
CaptainMike
Florida For Sale
Aug 14, 2017 04:17 AM
s2kohoh
Jun 27, 2016 01:12 PM
Zen1
Jun 10, 2016 06:25 AM
