Engine Torque Damper install help
Have anyone install an engine torque damper? Can you send me pictures of your install from the engine bay so i know where to install it.
In the guide they say you can adjust the dampening but how do you know the damper rate when there isn't a scale on there?
inside the damper there is 1 white rubber and 2 red rubber and it came as sequence as white, red and red.
*they also include 2 black rubber too but its softer then the red rubber.
Should be installed on left side of motor and you will need to cut into the stock heatshield or buy a pre cut heatshield such as the J's racing, and there will be issues when installing on an AP2. J's racing heat shield will not work with stock headers as well. I will dig up some pics tonight of my install.
KW-AP1
27
Sep 10, 2003 08:16 PM
