ever regret going with an aftermarket clutch?
#22
Originally Posted by S2KPUDDYDAD,Nov 24 2007, 07:29 AM
This is the set up I'm running now Billman250
I would say it would be a good recommendation to your customers. I have had a few different setups in my car from OEM to a 6 puck Exedy Hyper single and the Spec setup is the most enjoyable as far.
The peddle feel is light, lighter than stock but, the grip is much better, around 30%. I have the Spec light pressure plate (around 4 pounds lighter than stock) with OEM disc and OEM AP1 14 pound flywheel.
The combo is a more economical choice because you eliminate the cost of a light flywheel. By using the AP1 flywheel with the lighter pressure plate it is the same as having a 10 pound flywheel. You save upwards of $400
#23
I have the ACT pressure plate and OEM flywheel.I wish i had the stock clutch, but i need the ACT for the power my car has. 5k miles after S/C install the OEM clutch was toast..
#25
I love my Center force dual friction clutch kit with ClutchMasters flywheel.
i havent seen anyone with this clutch on the forum.
Im loving it to bits, 18 inch rims with 255 tires..spinning 3rd easily..amazing clutch
would never go back
would never go back
