Fabricating dual exit exhaust to single
Has anybody here done this? I came across a deal for a dual exit buddy club pro spec for $250 with a testpipe included so I couldn't pass up. But after reading the numerous "dual vs. single" threads, and my preference of a single exit look, i'm thinking of going to a muffler shop and having them fab up the dual exit into a single. Would appreciate any thoughts on this
Cut it at the rear Y and add a single from there, same size as the center pipe. Unless each single is the same dim. as the center pipe, which I highly doubt but if it was you could just cut&cap one side of the Y and make the other side a single that way.
ROD
ROD
One more thing you could do is leave one side stock(or put on a good single muffler on the side you want people to see) and put a cut-out on the other side with a turn down out of sight.
https://www.summitracing.com/search/department/exhaust/section/cutouts/part-type/exhaust-cutouts/product-line/quick-time-performance-electric-exhaust-cutouts?SortBy=Default&SortOrder=Ascending&autovie w=SKU&ar=1
loud and LOUDER, you choose when
ROD
ROD
https://www.s2ki.com/forums/s2000-mo...s2000-1184730/
I posted this recently, is this what you're asking about? pictures of underneath are at the end of the video.
Just hacking off one side of the dual exhaust will give the "look" you want and cut your exhaust flow significantly.
These cars have been around for so long that very capable single exhausts are available on the used market. Some of these have actual engineering in their designs (as opposed to me under the car with tubing and a welder!).
I've yet to find definitive information as to the inside diameter of the OEM exhaust. Guesstimates run from 50mm to 60mm. To get the same volume as a pair of 50mm exhaust outlets requires a 70mm system. If it's 60mm or larger even a 70mm exhaust will cut the flow. Getting into flow rates and harmonics is where engineering comes in. Nuisances like catalytic converters and mufflers further complete the process if you want more than "looks."
-- Chuck
-- Chuck
-- Chuck
-- Chuck
A single exit will definitely enhance exhaust flow to the point that tangible performance benefits are seen/felt. The rule is, the straightest path (least amount of bends or path diversions) for any exhaust is the most efficient. The dual look is very cool but not the best for greatest flow. And there are great single exit exhausts out there that look as great as they sound too
