FIPK and change in V-Tec point
Just wondering if this mod changes the v-tec point. It seems as though my V-tec point is only kicking in at 6200. Is this normal? I was just in my car and tested it out a few times and unless my eyes are playing tricks on me, v-tec is at 6200.
Can anyone comment on this?
Learning as I go as well...
A'PEXi has done it again with the release of the VTEC AFC (V-AFC), a piggyback fuel computer for VTEC engines. The V-AFC and the original Super AFC share similar fuel tuning capabilities with one big exception--changing the VTEC engagement point. The V-AFC is a very potent tuning weapon for enthusiasts utilizing performance camshafts in their VTEC engines. One of the common downfalls of VTEC performance camshafts is the dip in the powerband due to early engagement of the VTEC effect. By utilizing the V-AFC, you can eliminate the "dip" by engaging the VTEC later in the rpm, resulting in a smooth curve.
Originally Posted by fishs2000,Aug 27 2008, 10:36 PM
this may be a dumb question, but I have yet to learn what a vafc is?
Piggyback Fuel Computer with Integrated VTEC Controller
Modifies manifold pressure signal and alters VTEC engagement point on Honda VTEC engines; Vacuum Fluorescent Display (VFD).
A'PEX introduces the first digital fuel computer that combines fuel computer functions with a VTEC engagement controller. The V-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. The Fuel Adjustment function considers wide/narrow throttle and low/high camshaft settings, from which four different fuel maps are created (wide-low, wide-high, narrow-low, narrow-high). The integrated VTEC Controller adjusts the point at which the engine switches from the Lo to Hi cam during acceleration, as well as when the engine switches from the Hi to Lo cam during deceleration.
Due to the complexity of this product, A'PEX recommends having the V-AFC and other A'PEX electronics installed and tuned by authorized A'PEX Power Excel Shops.
ie. If you mash your foot down when it hits 6,000 rpm (give or take a couple 100 rpm), it will engage vtec everytime.
There are devices like a Apexi vafc that can manipulate the timing but I wouldn't normally want to mess with that until you have the unit installed and behind a dyno with a professional doing the tuning with a Air fuel tester
I HAVE APEXI VAFC2 ON MY AP1. HAD DYNO TUNED AND SET THE VTEC AT 5500. IT MADE 8 TO 10 MORE HP AND THE 5500 VTEC POINT IS PERFECT. IT MADE VTEC TRANSITION ALOT SMOOTHER. DEFINATE EASY TUNING FOR THE S. BOOMSLANG MAKES PLUGNPLAY HARNESS FOR 145.00.
