Vtec Adjuster
Old Oct 15, 2001 | 04:46 AM
uhear's Avatar
Default Vtec Adjuster
Someone I recently ran into was telling me about a V-tec adjuster. He said it allows you to lower the "rev point" at which it kicks in.
Anyone heard of this?
Old Oct 15, 2001 | 05:21 AM
Atmosphere's Avatar
Field makes one, so does Apexi V-afc, also about 2 others whose names escape me at the moment. It basically lowers the point the Vtec "kick-in" point. Very good mod especially for this car as it should bring the max Hp down in the rpm band to a more usable range.
Rick
Atmosphere Performance
Old Oct 15, 2001 | 06:02 AM
uhear's Avatar
Rick, thanks for the update, any web address'? I have a 2002 ordered---supposed to be here sometime in NOV early DEC and I just want to have my mods lined up waiting for the car.
Old Oct 15, 2001 | 06:25 AM
derryck's Avatar
Stocke VTEC engagement on the S2000 is set at 6000 RPM's. With the V-AFC (or other VTEC controller) you can lower the VTEC engagement to 5600 RPM's, any lower and you'll start loosing.
Old Oct 15, 2001 | 06:32 AM
uhear's Avatar
how much more effective will the Vtec be at 5600? Is there a control box for adjusting or is it a fixed feature?
Old Oct 15, 2001 | 06:44 AM
derryck's Avatar
If you use the Apexi V-AFC it's just a matter of pushing the buttons monitored by the LED style dispaly. Very easy after it's hooked up.
Old Oct 15, 2001 | 06:50 AM
uhear's Avatar
What is the performance advantage Apexi V-AFC adjuster? Noticable???? or Minimal? Does it risk harm to any other components?
Old Oct 15, 2001 | 10:23 AM
Wesmaster's Avatar
The V-AFC also allows for air/fuel mapping across the RPM ranges. You'll get more benefit form this than the VTEC engagement changes on an S2000. 10-12 HP has been seen from using V-AFC on stock S2000's.
Old Oct 15, 2001 | 10:27 AM
lvs2k's Avatar
[QUOTE]Originally posted by Wesmaster:
Do you have any actual documentation on these HP gains?
Old Oct 15, 2001 | 10:38 AM
Wesmaster's Avatar
[QUOTE]Originally posted by lvs2k
I know a HouStook that got 11 HP out of it (saw the dynos) and I saw another guy on the board here who got 12 HP.
