Sponsored by: CARiD
FIPK Replacement Filter?
Old Jul 15, 2011 | 03:32 AM
bnag0's Avatar
Default FIPK Replacement Filter?
Looking for a part number for the FIPK K&N air filter. I know i have seen it on here somewhere!?!
Old Jul 15, 2011 | 06:32 AM
Reckon's Avatar
http://store.knfilters.com/search/pr...x?Prod=57-3514
Replacement Filter - RP-4980
Should be what you need, however, the cost is $110 or so. I think it is part of the 'washable' series of K&N filters that allow you to use a cleaning kit from K&N, but I'm not sure.
Old Jul 15, 2011 | 07:36 AM
JDMpearlwhyteZ's Avatar
It's reusable..
So unless yours got into a freak accident, I'd buy the cleaning kit and reuse that puppy..
Old Jul 15, 2011 | 12:08 PM
rikhemi's Avatar
or just get the one with similar specs which cost 50 dollars and doesnt have the carbon fiber top. They are all washable from what I understand.
Old Jul 15, 2011 | 12:17 PM
Biohazard's Avatar
replace with the apexi universal 80mm filter. It is better than K&N and washable no oil needed.
Old Jul 15, 2011 | 12:23 PM
AEM dry flow FTW..
Old Jul 22, 2011 | 06:53 AM
bnag0's Avatar
The K&N FIPK Filter has an inside flange diameter of 102mm (4") I don't think the 80mm Apexi would work?
The AEM Dryflow does make a filter that has the 4" inlet but its 1.5" shorter than the K&N Filter (6.5"lg)
I think i will just buy another K&N, mine is all beat up from a previous owner and im not even sure if it was even cleaned, still works okay i guess, except for all the heat soak i experience at a stop mainly because its been around 90 degrees out the past few days.
Its just an eye sore, maybe ill just wash it and get one of the filter covers instead so it isnt so ugly...
Old Jul 22, 2011 | 07:12 AM
ian05s2k's Avatar
If it is just dirty, mine comes clean and looks nice again after I clean it. I usually have 2 goes with the cleaner, then 2 goes with the oil to make sure i didnt miss any spots. I do mine once a summer and it usually looks a little dirty, but it comes right out and when I am done, it looks great again. It is worth a try at least.
-Ian
Old Jul 22, 2011 | 08:02 AM
ian02s2k's Avatar
-Ian
I like your username Sorry to threadjack.
starchland
Jan 21, 2009 08:29 PM
sho-one
Oct 14, 2008 07:28 PM
wiixer
Mar 30, 2008 02:01 PM
Nate03
Mar 4, 2006 07:16 PM
av8tor2
Oct 19, 2001 08:19 AM
