Sponsored by: CARiD
fitting gauge pod on a pillar. line doesnt allow
Old Mar 10, 2010 | 07:37 PM
Frankenstiein_B20's Avatar
Unhappy fitting gauge pod on a pillar. line doesnt allow
i installed my dual pod onto my a pillar. heres the problem. for my oil pressure gauge, its mechanical so im using a -4 line.....this isnt allowing me to fit the gauge properly unless i flip it upside down because its hitting part of the pod. anyone have any ideas. was just going to cut the pod just enough to fit the line
Old Mar 10, 2010 | 11:11 PM
Chow-bot's Avatar
use electrical gauge
Old Mar 11, 2010 | 03:41 AM
trying to avoid electrical cause i have had problems with them in the past.
Old Mar 11, 2010 | 07:49 AM
deathsled's Avatar
sounds like you have your solution, cut the pod
But honestly, electrical is the way to go, I wouldn't want to run a pressurized oil line up near my face.
Old Mar 11, 2010 | 12:46 PM
well i solved it. the thing is those clear tubing lines that come with the autometer gauges crack very easy. so i converted to use a steel braided line. no problem =) n about the mounting. i went ahead and and bought an autometer single gauge pod mount n mounted under dash where its still visible and them my wideband and (soon) boost gauge will go ahead and be mounted on the pillar
Old Mar 11, 2010 | 01:03 PM
Neutered Sputniks's Avatar
Especially not when the oil pressure on the F20/F22 gets up to, oh, 80-100PSI on a regular basis... That's a lot of pressure behind hot oil...
If you had problems with an electrical gauge, was it because it was poorly installed or poorly designed?
I've had a PLX OP gauge for 6 mos with the only problem being a loose connector at the sending unit
Old Mar 11, 2010 | 09:24 PM
it was an AEM, had 2 sending units go bad and they WERE installed properly. steel braided lines can easily hold over 100psi. never had a problem with them but i can see how people would worry. they both have pros and cons.
razzele
Aug 17, 2017 06:47 AM
Reaper 6A
Feb 23, 2007 12:15 PM
S2KMan2000
Feb 16, 2006 06:10 PM
craigjcoil
Aug 9, 2004 10:19 AM
