Sponsored by: CARiD
Forged Internals, Nitrous
Old Nov 26, 2010 | 06:36 PM
durtbikedude365's Avatar
Default Forged Internals, Nitrous
I have a 2002 AP1 S with: fully forged internals, 89mm bore, and stock 11:1 compression. I'll also have an Invidia 70mm Header, test pipe, and exhaust very soon. What kit of nitrous shot do you think I can handle? I was considering a 125 shot, but I'm not sure. Any input is appreciated.
Thanks
Old Nov 26, 2010 | 08:46 PM
Luis06s2k's Avatar
Well 1st off... Are u considering a "Wet" "Dry" or "Direct port" shot.?
I've seen members run a Direct shot of up to 125 shot on stock ap1 motors with only a fuel pump and moderate tune. There's alot of members on here on Nitrous... Search around for a bit and u will find alot of good information regarding Nitrous.
Old Nov 27, 2010 | 05:58 AM
Gernby's Avatar
Former Sponsor
I think it depends entirely on your setup and tune. If you just want to throw on a cheap wet kit with a stock ECU, then I doubt your motor will last long with anything more than a 50 shot.
Old Nov 27, 2010 | 06:11 AM
suzuka-blue-s2k's Avatar
If I remember right, you can run up to a 75 shot with the stock timing and stock ECU. Anything more than that it would be way to dangerous. If I ever run nitrous, I wouldnt run over a 50 shot without an EMS and a good tune. If your wanting to do a 125 shot, look into direct port injection, and a nice EMS to tune with.
Old Nov 27, 2010 | 06:43 AM
Gernby's Avatar
Former Sponsor
If he had an '00-01 ECU, then a 75 shot would be safer, but the '02-'03 ECU was tuned more agressively from the factory. I don't think it would be wise to run 75 shot with an agressive tune.
Old Nov 27, 2010 | 08:43 AM
Well, I will retard the timing, and I will be running an FI/C along with a wideband o2 sensor to monitor the fuel to air ratio and keep it all safe. I was considering doing direct port, but it seems like it would be overkill when im only running a 125 shot max.
Old Nov 27, 2010 | 12:19 PM
Moddiction's Avatar
Former Sponsor
I wouldn't run it with an AEM FIC. garbage tuning devices for AP1's!
Old Nov 27, 2010 | 02:35 PM
Suzuka_Joe's Avatar
So you have a "built" motor with stock intake, exhaust, and header?? And running a stock ecu?? Why....
Old Nov 27, 2010 | 06:12 PM
Good question, I've gotten that one alot actually. I spun a bearing back in June driving the car way too hard, since then the stroker kit has been my first investment on the project. I don't have anymore money at the moment so the rest of it is coming one step at a time... Currently I am driving my stroked s2k with stock header, exhaust, I have an AEM intake, and stock ECU running un-tuned. Sounds bad, but it is safe to drive as long as I keep it under roughly 4500 RPM's so it doesnt run too lean.
Old Nov 27, 2010 | 11:13 PM
Moddiction's Avatar
Former Sponsor
Don't blow the engine from driving too hard. Probably had low oil most likely.
