Sponsored by: CARiD
Front bump steer kit problem
Old Jan 2, 2015 | 04:25 PM
fifty5engineering's Avatar
Default Front bump steer kit problem
The 12mm front bsk I am attempting to install doesn't seem to fit right. When I put the bsk kit under the steering rack, I can't slide the rack back far enough to to line up the holes on the driver's side. I can force it, but the rack won't be equally mounted on the sub frame. Is there something in the way Im not seeing? I loosened and moved the radiator clamp out of the way. It seems like the steering shaft is too long to allow the rack to slide back once raised by the bsk.
Any ideas?
Old Jan 2, 2015 | 05:36 PM
AE_Racer's Avatar
There's a joint further up the shaft. You can loosen it and this will allow you to move the shaft a little further backwards or forwards. I had to loosen mine to get my spacers in as well, IIRC. It's been a few years.
This article doesn't mention it but it's a nice DIY and you can see if there's anything else you may be missing
http://robrobinette.com/S2000FrontBump.htm
Old Jan 3, 2015 | 08:30 AM
Thanks! Your suggestion worked.
Old Jan 3, 2015 | 06:53 PM
AE_Racer's Avatar
No problem
RichwiththeS2000
May 5, 2014 01:55 AM
Hondahero10
Jun 14, 2013 12:41 AM
choleaoum
Dec 7, 2012 08:43 PM
killyougood
May 19, 2009 06:35 AM
