Sponsored by: CARiD
Gear Shift Insulator
Old Apr 21, 2021 | 11:23 AM
WidWidi's Avatar
Post Gear Shift Insulator
Anyone know what this is made out of? What is it's purpose?
I think it would be possible to make one myself, instead of pay Honda OEM.
Thanks.....WidiWidi
Old Apr 21, 2021 | 03:13 PM
Car Analogy's Avatar
Some sort of soft foam rubber. It prevents hot air off trans from entering cabin. It turns to sticky, nasty mush. I replaced mine when I did the clutch a few years ago, and when recently doing audio system, noticed its disintegrated again.
Car used as 3 season dd. No track. New England, so not super hot climate.
I have a brand new one still in Honda bag waiting for when I do the next round of audio work and have to remove console cover.
I was planning to trace it and measure it in case it becomes unavailable, so I can diy make one.
Maybe I can post it as a template that can be printed out, for others to diy. Suggestions how to post and retain scale?
How do they do that for printing out bbk fitment templates?
Old Apr 21, 2021 | 03:18 PM
A1A-S2K's Avatar
When I pulled my center console to run sub-woofer wiring, my shifter insulation...like everyone else's was deteriorated into a crumbled, sticky mess. I believe it's purpose is sound deadening and possibly some transmission heat barrier to the console/cabin. I just went to Home Depot and bought some Frost King window/ac weather-stripping foam for $2. Worked just fine
Old Apr 22, 2021 | 07:28 AM
WidWidi's Avatar
Post Insulator
The template isn't to scale (s2000Insulator2.pdf), but it could be if you want to provide the measurements from yours.
Depending on how accurate you want to be you could use millimeters or whatever.
Open it up in Adobe Reader. Put in the measurements. Send it back to me, and
I will make a template to scale. Sound good?
What material? And where were you going to purchase it from to make
a duplicate of it?
File Type: pdf
Old Apr 22, 2021 | 09:32 AM
Live Fast's Avatar
Yeah the factory insulation seems to fall apart after so many heat cycles. At $25 from Majestic I would hold it lasted longer.
I'm curious to see if anyone else has used a different foam to replace it.
Old Apr 22, 2021 | 10:14 AM
shrykhar's Avatar
What the others said ... from the condition of the original insulator it doesn't look like Honda used anything special. I picked up a chunk of foam and cut out my own from Home Depot, checked it recently and it hasn't gone to mush like the original part had.
Old Apr 23, 2021 | 04:04 AM
a duplicate of it?
I have digital calipers. I'll make some measurements and send back to you. Collaboration!
Old Apr 23, 2021 | 05:10 AM
randomwalk101's Avatar
I just use a pipe foam insulator and just stuff it down there around the edges. Doesn't have to be perfect.
Old Apr 23, 2021 | 05:58 AM
WidWidi's Avatar
Post
Alright!
Old Apr 23, 2021 | 09:14 AM
Dimensions:
ID 120mm
Thickest end 30mm
Thinest side 10mm
