Sponsored by: CARiD
Greddy cat back install?
Old Aug 8, 2011 | 02:30 PM
s2knkde's Avatar
Default Greddy cat back install?
hey guys, I just purchased a greddy ti-c dual cat back. I know it says it requires ap1 hangers but I have heard of people using ap2 hangers turned sideways. Does anyone have experience with this?
Also, I have limited mechanical knowledge and skills but I'm not familiar with the s2000 exhaust system. Is an aftermarket cat back install simply a bolt-on or is welding required? Please advise, thanks!
Old Aug 8, 2011 | 02:54 PM
jh4db536's Avatar
I'm buying 2 muffler hangers because the ap2 has triangle shaped ones (works but alignment is a little weird). You need the regular 9.5mm oval shaped ones should cost 5 to 10bucks.
The stock exhaust is one piece from the cat. Take off 3 nuts on the cat, drop the rear tie bar in 3 bolts, spray the bushings with wd40 and pull the exhaust off the hooks. You can probably install the greddy assembled in one piece. On a lift it would take 30minutes to install. On ramps maybe an hour.
Sent from my T-Mobile G2 using Tapatalk
Old Aug 8, 2011 | 06:41 PM
s2knkde's Avatar
Could you point me in the right direction to buy the ap1 hangers then? Thanks for the info!
Old Aug 8, 2011 | 10:06 PM
jh4db536's Avatar
Well the easiest place is to get them from honda...could probably steal one off a civic or integra. The ap1 bushing is standard, its the ap2 bushing that is different. Aftermarket t1r hangers, apexi
Old Aug 10, 2011 | 09:42 AM
s2knkde's Avatar
Well, change of plans. Greddy was backordered everywhere and I need this soon so I bought an Invidia v3 off a forum member in the marketplace. Any difference on the install process? Also, do I need aftermarket gaskets or anything in order to install an aftermarket cat? Sorry but I really know nothing about exhaust system mechanics.
Old Aug 10, 2011 | 09:53 AM
justind's Avatar
you can use the oem ap2 hangers, dont worry. I used them with my invidia. If it didnt come with gaskets you need one for the cat to mid-pipe, as well as the y-split to the mid-pipe. Install is super easy and even on jack-stands it should only take you 30 min. Be careful dropping the oem exhaust, its heavy!
Old Aug 11, 2011 | 12:50 AM
s2knkde's Avatar
Thanks a lot! that's exactly what i needed to know
MIP
May 16, 2014 10:14 AM
kerm1t
Jan 21, 2012 04:13 AM
rc11
Aug 22, 2009 12:21 PM
BulldogS2
Jun 1, 2007 05:42 PM
emrillive
Apr 27, 2004 04:25 AM
