Sponsored by: CARiD
Header install
Old Nov 14, 2008 | 10:04 AM
kamui157's Avatar
Default Header install
I have a used header to install but do not have any additional hardware. What do I need to install the header? Can i use all the original bolts and header gaskets?
Thanks
Old Nov 14, 2008 | 10:17 AM
LostMotion's Avatar
yes
Old Nov 14, 2008 | 10:18 AM
wisdom's Avatar
The bolts should still work. I would get new gaskets though. What kind of header do you have?
Old Nov 14, 2008 | 10:27 AM
kamui157's Avatar
Comptech
Old Nov 14, 2008 | 12:06 PM
LostMotion's Avatar
The gasket will be fine.
Old Nov 14, 2008 | 02:44 PM
g352s2k's Avatar
you will have to remove a bracket from underneath the car that is bolted to the oem header. Make sure you have a breaker bar....it makes it so much easier...with a breaker bar i didn't even use WD40. It took me about 2 hours last night and that was with me jacking around. For sizes you will need 12mm and a 14mm to remove that bolts. Thats all I used. Maybe a 10mm to.
Also make sure you remove the o2 sensor before you unbolt the header.
Old Nov 14, 2008 | 02:52 PM
jettfiery's Avatar
2 hours? it took me about 30 minutes to install mine. And yes BREAKER BAR is essential if your car is a few years old. This car was WAY easier than my Saleen ever was...
Old Nov 14, 2008 | 03:26 PM
LostMotion's Avatar
I broke that tab off on a brand new car. Spraying it with WD or Liquid Wrench is a good idea.
Old Nov 17, 2008 | 05:21 AM
NVMY4N's Avatar
SEARCH
DIYs
MattZ28
Nov 21, 2010 04:13 PM
whiteflash
Sep 24, 2010 03:43 PM
whiteflash
Aug 13, 2010 06:58 AM
Ro_Ja Boy
Apr 13, 2005 04:18 PM
revhard
Aug 14, 2001 01:38 PM
