Sponsored by: CARiD
Installing new (used) header
Old Aug 12, 2010 | 12:21 AM
whiteflash's Avatar
Default Installing new (used) header
So my comptech 4-1 header just arrived that I bought off the forums. This will be my first time installing a header and I had a quick question. Should I be replacing any gaskets, or are they fine to re-use?
Also I'm assuming installation is straight forward...
- Unbolt heatshield
- Remove AF sensor
- Unbolt from cat
- Unbolt from engine
and install the new piece? Any weird quirks I should know about? Thanks guys
Edit: I've read I may need to jack the engine up a bit, also consensus seems to be remove the old one from the bottom, install new one from the top??
Old Aug 12, 2010 | 01:48 AM
realblag's Avatar
Well, the manifold gasket is relatively inexpensive so you might as well replace it so you don't have to worry about exhaust leaks. The donut on the other end should be fine unless you knock a chunk out of it somehow. There are several threads concerning removing your factory header. Its actually a PITA. I think its best to remove it from the bottom but opinions vary. GL
Old Aug 12, 2010 | 02:25 AM
whiteflash's Avatar
Also another question while I have this thread open: Heat management, what are my options?
I've read that heat-wrap can cause premature cracking. Is this only with traditional wraps? Would say, DEI Titanium heatwrap suffer the same problem?
http://www.designengineering.com/category/...p-lr-technology
And then there's coatings, but I'm unfamiliar about the options in that department. Thanks again
Old Aug 12, 2010 | 04:04 AM
chef-j's Avatar
I will replace gasket.
When I had headers on my previous car, I went with jethot, I was happy with it. I'm not fan of wrap manifold or exhaust pipe, there are many option/info/pros/cons about wrap vs coating thru other forums.
Old Aug 12, 2010 | 05:20 AM
MasterForce's Avatar
if the header doesnt go through under or over you might have to remove the engine mount and lift the engine a bit. makes it easier to fit.
Old Aug 12, 2010 | 05:50 AM
FISH22's Avatar
Each header usually goes in a certain way, depending on it's design. For my ASM header, I had to remove the passenger side motor mount, AND jack the engine up about 2 inches.
I'd also recommend installing a new donut gasket and flange gasket.
Old Aug 12, 2010 | 06:13 AM
whiteflash's Avatar
Do you happen to know the part numbers on those Fish22?
Also, The part numbers on the flex bolts at the cat/header joint? I heard those are prone to breaking
Thanks guys appreciate the help as always
Old Aug 12, 2010 | 07:28 AM
Parts 9 and 10 and 17. You will need 2 of each.
http://www.hondaautomotiveparts.com/auto/j...y5=EXHAUST+PIPE
Old Aug 12, 2010 | 07:31 AM
FISH22's Avatar
Majestic is the best place to get the stuff you need.
Old Aug 12, 2010 | 07:34 AM
FISH22's Avatar
Also, here is the illustration for the flange gasket. It's #3
http://www.hondaautomotiveparts.com/auto/j...XHAUST+MANIFOLD
The donut gasket is in the other illustration posted, and it's #8.
