headers
Im looking at getting the invidia header for my AP1, however i was wondering what if any problems i will run into with the computer. I have the test pipe however i have the CEL on for it. Will the ECU change too much of the MAP to run ok or will i need to have it tuned when i install this. Any advice would be great. thanks.
Test pipe will lean out the mixture, the header will do it even more.
The car runs rich to begin with so you're balancing it out to more "optimal" air to fuel rations (12's), if you get into the mid to high 13's+ you will damage the motor over time
Originally Posted by philbert,Aug 25 2009, 11:51 AM
if the stoichiometric ratio is 14.7, then isn't 12s going to be "rich" in pretty much any application?
Run 14.7 all you want, just make sure the gas, temperature, air are always the same all the time
