help, cel is on (berks TP)
yes i have the CEL fix built in, i just searched the forum for similar problems, and found an angled CEL eliminator. Would this work? is that the same thing a an anti fouler?
I have the same problem as you... you can try the cel angled elimintor option but mine still came back (and I failed my emissions test so many times that I became the mayor of the emissions center on foursquare.. .
) oh, and i tried the steel wool option as well and that didn't work.
With an '06 and up, even if you unplug/clear the CEL, after so many miles, it'll come right back up.. and if you are running an emissions OBD2 test, it'll be still fail.
I gave up and went to the OEM cat for now.. .interesting that your HKS set it off though.. with the Berk and HKS, my CEL never came up but when I switched to the Mugen, the CEL popped up...
this spring i'm going to go flashpro and at that time, i'll have the code cleared and the berk back on.
) oh, and i tried the steel wool option as well and that didn't work.With an '06 and up, even if you unplug/clear the CEL, after so many miles, it'll come right back up.. and if you are running an emissions OBD2 test, it'll be still fail.
