Sponsored by: CARiD
Help Emblem adhesive extremely hard
Old Mar 8, 2013 | 02:55 PM
smad's Avatar
Default Help Emblem adhesive extremely hard
So i tried taking off my emblem and this is what is left...
It is extremely hard. I tried the blow dryer and adhesive remover. none work. Scrubbing doesnt work. Any 1 know if buffing would take this off? or any other method...
im thinking if it doesnt work ill just put black emblems on the side...
Old Mar 8, 2013 | 02:57 PM
s2000ellier's Avatar
be very careful or else you will take the paint off. if a blow dryer isn't hot enough i'd suggest using a heat gun. prepare to burn your thumb and fingernails
Old Mar 8, 2013 | 03:16 PM
alphalanos's Avatar
i alternated between soaking it with goo gone, and using a rag wrapped around my finger or just my bare finger. if you rub enough the friction will heat up and help take it off.
Old Mar 8, 2013 | 03:27 PM
smad's Avatar
i did as you said and nothing. It is hard as rock. no movement what so ever, even if i heat it up, use goo gone. nothing.
Old Mar 8, 2013 | 03:45 PM
s1mba's Avatar
I had the same issue with mine.. be careful because I ended up chipping paint
I got the driver side off fine though. I just heated it up to get chunks off and then I used goo gone for the rest. I then put a few coats of ScratchX 2.0 and it looked like new!
Old Mar 8, 2013 | 04:13 PM
s2cho's Avatar
http://www.amazon.com/3M-7498-STRIPE.../dp/B00063VT0G
use a wheel and it will come right off. i on the other hand am cheap and i used a razor blade. came off perfectly with no dmg to the paint but i know how to cut the adhesive and not the paint... very steady hand...
Old Mar 8, 2013 | 05:44 PM
Andersonracing's Avatar
Gasoline. Use it on racecars all the time to remove the door number goo. doesnt dull the paint one bit and it will get that off in a heartbeat.
Old Mar 8, 2013 | 08:46 PM
AP1_Silverstone's Avatar
Paint thinner
Old Mar 8, 2013 | 10:26 PM
JesS2000's Avatar
Paint thinner, bestine or denatured alcohol. Try all 3. At least one will work
Old Mar 8, 2013 | 11:07 PM
nofearofdanger's Avatar
Have you tried Prep-Sol?
