Help Emblem adhesive extremely hard
googone is magic.
Barring that, try the 3M adhesive remover wheel. It attaches to your drill- expensive product, but the right tool for the job.
http://www.amazon.com/3M-7498-STRIPE.../dp/B00063VT0G
good luck
darcy
good luck
darcy
Well time to go pro, you gonna need a real buffer machine and a really fine robbing, 3m sells small cans or 1-2-3 steps robbing, you will need to get #2 step and a foam wheel for the buffer, it will take all the impurities off the paint, is really easy to do, I did my whole car and it was my first time ever.using that kind of equipment. There should be some videos on YT bout it so u can get an idea. Otherwise u will have to take it to the shop...
Originally Posted by JesS2000' timestamp='1362813980' post='22391266
Paint thinner, bestine or denatured alcohol. Try all 3. At least one will work
Another problem you run in to is the paint underneath the emblem is actually a different shade because it hasn't ever seen weather. After a few months it's not noticeable but no matter how much buffing/waxing you do in that area you will see the faded remnants of your emblem for a while.
I ended up using a very abrasive towel, florida sunlight, and most of the skin off my both my hands to get mine off. At the end of the day; i successfully removed all the tape. Turns out I also ended up removing some of the paint too. That tape they use is no joke when it has 10+ years to adhere to the car.
