Sponsored by: CARiD
Hondata FlashPro
Old Jun 18, 2009 | 06:17 PM
thesilverbullet's Avatar
Default Hondata FlashPro
have you guys seen this?
D@mn sweet mother!
this is kpro for si without ecu mods and access via the service port.
i hope we get this for the s2k ('06+ guys) and get rid of the rsx kpro piggyback...
Old Jun 18, 2009 | 06:20 PM
http://www.hondata.com/flashpro.html
FlashPro features
Programmable ECU interface.
Connects via OBDII diagnostic port.
USB 2.0 connection
Works with Laptop or Desktop
No ECU modification necessary.
90 second ECU programming time.
20 hours on board datalogging memory.
FlashProManager Windows software.
Check and clear diagnostic codes.
Custom laptop gauges.
Dual calibration storage - upload from one of two calibrations stored in the FlashPro
2006+ Civic Si / Civic Type R AFM/MAF based calibrations
Ignition, fuel, cam angle table editing.
VTEC window.
Rev and launch limiters.
AFM calibration table.
Map tracing & lambda overlay.
15 starting calibrations for common intakes and race header combinations.
2006+ Civic Si / Civic Type R MAP based calibrations
Above features plus:
Expanded fuel, ignition & cam angle tables for forced induction.
4 bar MAP sensor support (40 psi).
50 degree cam angle movement for more midrange torque. (up from 45 degrees maximum)
Support for larger injectors.
Injector latency / dead time.
Individual cylinder fuel & ignition trim.
Race vehicle sensor disabling.
Speed limiter removed.
22 starting calibrations for intake, headers, forced induction & injector combinations.
What do I need to run the software?
Windows laptop or desktop
Windows XP, Vista or 7
USB 2.0 port
CD-ROM Drive
Macbook (Intel) running Bootcamp with the above specifications. Has been extensively tested and works well.
Macbook (Intel) running Parallels with the above PC specification. Has been partially tested with no problems found to date.
Training videos
Old Jun 18, 2009 | 06:29 PM
"The FlashPro has the potential to work with most new model Hondas and Acuras made since 2007. Our focus for the moment is for the Civic and will evaluate other models as time permits." - Hondata
Old Jun 18, 2009 | 06:32 PM
KPro is a completely different product. It was created for the 02-04 RSX style ECU. It will only work on that type of ECU with the exact same Oki processor. Honda has changed the architecture of the ECU, including ECU architecture, processor and encapsulation, so that there is no way the KPro can be made to work on any other ECU.
K-Pro requires the ECU be sent to a Hondata for the installation of the K-Pro daughterboard. By comparison, new FlashPro owners need never remove the ECU from their car.
"Because FlashPro is a different product from KPro, it has different features. Not all features implemented in KPro are possible with FlashPro.
The Flash Pro will not have boost or nitrous control. However if you have an external boost controller the Race calibration will deliver the correct fuel and ignition for that boost level.
If you run nitrous, you will be able to run a calibration that is far safer and make more power than you would with a stock ECU." - Hondata
Old Jun 19, 2009 | 04:27 PM
King_'s Avatar
I would buy tomorrow! Being a former hondata supporter I would love to see something like this for us
Old Jun 22, 2009 | 10:33 PM
troy611's Avatar
Yes, I also want to support Hondata. I will buy the FlashPro as soon as it is released for us....
The Toda Relash would be a good map to start with when using the FlashPro? Then tune for the mods that I have.
We should all tell Hondata how many of us would like this FlashPro in hopes that they release it for us sooner than later.
Old Jun 22, 2009 | 11:23 PM
ans2k's Avatar
true, but for those who bought the reflash. damn, there better be a big discount.
Old Jun 22, 2009 | 11:41 PM
GrandMasterKhan's Avatar
This is exactly why i own an 06+ s2000. I knew it would only be a matter of time before something like this was available for the S
Old Jun 22, 2009 | 11:47 PM
jaeyon00's Avatar
dam why isnt there anything for the ap1s? is there any open source tuning hardware/software available for the s2000s at present?
Old Jun 23, 2009 | 09:23 AM
CASTRO's Avatar
if you got an AP1, just go stand alone for ultimate flexibility
