Sponsored by: CARiD
HT help
Old Feb 6, 2009 | 11:16 AM
milkman2089's Avatar
Default HT help
has anyone had problems with alignment on their ht
driver side is perfect
but i cant seem to fit the passanger side
there is still a gap and can see outside the car
thanks
Old Feb 6, 2009 | 11:20 AM
Integra21's Avatar
try attaching the passenger side on first... ?
bump for help
GL
Old Feb 6, 2009 | 11:25 AM
RFCR's Avatar
Make sure latch is all the way back. If still to high, then the bracket on the HT underneath the liner needs repositioning. Manual for the this is online.
Old Feb 6, 2009 | 11:40 AM
Chris_Lum's Avatar
yes looks like you just need a readjustment. remove the plastic interior panel on the inside of the HT (on the side that has a gap), loosen the bolts on the bracket that you see, adjust as necessary (push the HT down in your case) and tighten the bolts back up.
vtecmonster
May 8, 2020 07:45 AM
deepbluejh
Dec 3, 2013 08:43 PM
MurderS2K
Sep 15, 2010 07:06 AM
TommyS2000
May 15, 2010 01:30 PM
mtm584
Dec 19, 2003 05:25 PM
