Sponsored by: CARiD
Improved knock sensor
Old Apr 20, 2017 | 08:38 AM
s2kpotenxixe's Avatar
Default Improved knock sensor
Did anybody install one of this in our car?
Amazon Amazon
since de oem has another bolt design... what type of bolt did you use?
kind regards
Old Apr 20, 2017 | 12:25 PM
Car Analogy's Avatar
There is an oem component that screws into the location perfectly, plugs right in to the wiring harness connector, and was designed specifically for this engine by engineers with Formula 1 backgrounds.
And you want to use something else that is generic instead? That has to be adapted to fit, and spliced in to the wiring. You somehow think this would be a better solution?
Old Apr 20, 2017 | 12:34 PM
Well... the oem one gets a lot of noise from the engine. This one from bosch has a better noise filtering and a good mod if you are running a standalone.
Old Apr 21, 2017 | 03:37 AM
AngryTurtle's Avatar
God forbid someone in the last 2 decades created a better knock sensor.
Old Apr 21, 2017 | 07:07 PM
If its one that fits the block and the wiring harness, great! If it has to be cobbled together, no thanks, not for me...
Old Apr 22, 2017 | 02:21 AM
noodels's Avatar
Any reported issues with Knock sensor signal using non OEM forged pistons as they are known to have some noise on start up ?
LiveFast
Nov 30, 2015 08:53 AM
mroverkill
Sep 16, 2015 04:04 PM
skool u
May 13, 2010 02:07 PM
PistolPete76
Mar 18, 2010 08:29 PM
jwa4378
Mar 28, 2009 02:10 PM
