Sponsored by: CARiD
Intake Install DIY
Old Feb 12, 2010 | 10:30 AM
SilverS2kF22C1's Avatar
Default Intake Install DIY
Haven't done a write up in a while and not one for a Honda S2k so I figured this was a good one to start with. I tried search but it's always hit or miss with me so I hope it's not a duplicate!
This DIY covers the installation of a PRM Racing Jet Stream intake system on a 2005 Honda S2000. I am sure it is applicable to other years and other intake manufactures. On a scale of 1 - 10 for difficulty I would rank it a 2, quite easy and no special tools are needed.
Tools needed
10mm, 3/8 drive, Socket
6" 3/8 extention
Needle nose pliers
Small channel lock or line's mens pliers
8mm, 1/4 drive, socket
3" 1/4 extension
#2 Phillps Screwdriver
Small flat head Screwdriver
You should also get a small section (approx 6") of stiff mounting plate to make up a bracket, you'll see why later on...
So this is what we start with Not very flattering
We will be pulling that intake system out and installing the PRM Intake from these pieces
Where to start...
Whelp lets start here... Pull the sensor lead out of the clip on the stock intake tube (sensor is located on the throttle body)
Next using a small pair of channel locks or line's mens pliers undo the large clip on the lower right side of the intake and disconnect the hose
Next use the #2 phillps to undo the throttle body intake hose clamp
Undo the Spring clip on the valve cover breather line at the intake
Next remove the airbox top cover
And now remove the stock intake tube (I did the airbox mod last summer so yours may look a bit different inside)
Next on the lower intake box locate and remove the vacuum in-line solenoid from the lower intake (SUCKER IS TIGHT!)
Now disconnect the wire retaining clip using the needle nose pilers, this will keep it from being damage in case you decide to go back to stock
Next remove the vacuum lines from the lower intake box clips
The large hose disconnect earlier from the stock intake tube is also held in with a clip
Now undo the 3 bolts holding the lower intake box using the 10mm socket (2 on the left side and one on the right side) but don't go pulling it out just yet
Once you get the box unbolted you can get at one more set of vacuum line clips and wire retaining clip off the back of the box
Now lift the box out... Looks pretty baron in there! You will notice in the picture the vacuum in-line solenoid hangs pretty close the the serpentine belt and has no place to attach. Go ahead and disconnect it from the hard line near the top of the motor, will get back to once the intake is installed
Next remove the valve cover breather hose and rubber joint from the valve cover. Using one of the supplied zip ties pull it back tie it off on the fuel rail. Make sure you don't pinch any lines or wires when you do. Doing it like this eliminates the need to re-plumb ALL the vacuum lines and the throttle body coolant lines.
Now install the intake tube using the supplied silicone coupler and hose clamps, just get everything snug to start you may need to rotate it around to get everything lined up. Once it is installed use the large silicone tubing from the kit to connect the intake to the valve cover breather port. I put a bit of WD-40 on the connection points to make it easier to slide the tubing on, I also tossed the factory clamps back on but you don't need too.
Now you can install the PRM Jet Stream filter with funnel to the intake tube (sorry don't have a pic of that)
Remember the vacuum in-line solenoid... Well now we finish it. Remove the short line from the solenoid and replace it with the long vacuum line from the kit, reconnect it to the hardline at the top of the motor, using the other supplied zip tie it to the wiring loom that runs along the front cross member. Don't pull it to tight you don't want to crush the lines! (I used a few more just to keep it clean looking)
Now reconnect the large tube on the lower right side of the intake, and using the 8mm socket tighten up all your clamps, then stand back and admire your work... But there is one problem...
The problem is that PRM Racing does not supply a mount for the filter end of the intake. Basically it flops around, not good... What I ended up doing was fabbing up a "S" shaped bracket to go under the funnel clamp and attach to one of the stock lower air box mounts. This keeps the intake from flopping around. Don't over tighten it or you can damage the funnel piece
So now let's start up the car and see how it sounds!
(vids may still be rendering so be patient)
S2k PRM Racing Intake Revving[media]http://www.youtube.com/watch?v=OA_rsLuzmTQ [/media]
Nice that sounds good! Now to test drive... To bad you really can't hear it over the exhaust (Invidia N1) nor do you really get a sense of how loud the car is to start with
S2k PRM Racing Intake Test Drive[media]http://www.youtube.com/watch?v=LdHJx8hy82k [/media]
Now did it make a difference.. Well I think it did, here is what I noticed:
1. The exhaust has a deeper tone
2. The throttle reponse is a bit snappier
3. The mid range doesn't feel as a flat as it did
4. VTEC engagement feels/seems softer which make's me think the midrange saw some gains too, which aligns with the mid range improvement I noticed
5. Can't hear it on the video but once VTEC engages you can HEAR the air rushing into the intake. Very cool
Probably won't be able to dyno the car until the May time frame so I have no numbers on what it did really gain, but it is a noticeable improvement over the stock box!
Overall I am quite pleased with the install and the PRM intake, but I do think PRM should throw in the bracket though...
I hope people find this helpful if they tackle this fairly straight forward install!
Old Feb 12, 2010 | 10:49 AM
RAYZ-Ace's Avatar
when i spoke with Gerry about the bracket he said it wasn't necessary since it moves with the engine,
GOOD DIY Too!
Old Feb 12, 2010 | 11:10 AM
Thanks
I thought about not bracing it but it just seems like to much mass hanging out in space and felt it best to tie it down. The silicone couplers still have enough wiggle room to let the engine move around... But that will soon be reduced once I get the engine dampener installed.
Old Feb 12, 2010 | 01:16 PM
s2krev's Avatar
That's very cool... interesting intake o.O I like it.
Old Feb 12, 2010 | 03:12 PM
mister x's Avatar
Great DIY! If anyone else is thinking about getting a PRM intake, I recommend buying a second air filter at the same time. When cleaning, you can swap out with no down time waiting for it to air dry (and don't tell me you drive around to dry it out). Also it's not a common size and hard to find (at least in my small town).
Old Feb 12, 2010 | 04:23 PM
s2k aok's Avatar
awesome diy, i've had two prm intakes...
Old Feb 12, 2010 | 04:28 PM
s2k aok's Avatar
https://www.s2ki.com/forums/index.php?showtopic=743370
Old Feb 12, 2010 | 05:01 PM
Very nice... I have been toying with trying a crinkle finish on the intake tube like the valve cover... Maybe I still will
Old Feb 13, 2010 | 05:55 AM
03BlkS2k's Avatar
nice write-up........ going to be picking up a prm intake here soon
Old Feb 13, 2010 | 08:52 AM
sillyboybmxer's Avatar
nice write up and vids
