Invidia Header Problem
Hey guys I installed a Invidia Header on my '07. I have just over 50,000 miles....(I know its a crap load of miles for a 07) and when I turn to the left under acceleration the header hits the inner fender well. I figured this was the motor mounts loosening up and the motor moving more under accel.. It is a long tube header so it is pretty close to the fender well. I do enjoy the power of the car more than I should, so I don't know if I should buy new motor mounts or heat up a small part of the fender well and bang it in slightly. I am also not sure if getting new motor mounts would even fix the problem because I had the header in about 6 months earlier and I did not have this problem. Anyone ever have a similar problem or know whats best to do?
You can try an engine damper.
http://www.evasivemotorsports.com/Merchant..._Code=ETD-S1-SL
and this
http://www.evasivemotorsports.com/Merchant..._Code=JS_HS_AP1
and this
