Help with invidia header install
Old Aug 24, 2007 | 08:42 AM
Madhatchz's Avatar
Default Help with invidia header install
I have read most the header install threads (including xvipers) and i can not find help for my problem.
I removed the DC header that came on the car (very easy) and now im installing the invidia header. I have the header about half way seated right above the header studs. The problem is this, i can not get the header over the studs due to the fact of the header itself hitting the frame/firewall? (right below the battery/fuse box). The header design is bigger then the DC and that is why i am having problems.
What i have done so far, very carefully wedged a large screwdriver in there to push the motor out of the way to slip the header on, and i have jacked up the motor aswell. BTW i installed this header from the top.
Help! I have grease on my hands right now and im trying to finish!
Thanks in advance!
Old Aug 24, 2007 | 09:30 AM
S2KPUDDYDAD's Avatar
Try installing from below, I have never had any luck installing from up top
Good luck
Old Aug 24, 2007 | 09:33 AM
jirro22's Avatar
yep..
Old Aug 24, 2007 | 09:37 AM
Madhatchz's Avatar
Its the forward two studs that are giving me clearance issues, but ill give it another shot from the bottom.
Old Aug 24, 2007 | 09:55 AM
Madhatchz's Avatar
How much force should i use coming from the bottom, should the cleanance be fine with the tranny housing/block/firewall, or do i need to pry on it?
Old Aug 24, 2007 | 10:17 AM
pitstops's Avatar
you gotta use some good force.
Old Aug 24, 2007 | 02:49 PM
It should go right in with a bit of finesse, no prying or any forcing. If you pry or force it you could damage the header by putting a dent or puncture in a tube.
Old Aug 24, 2007 | 06:53 PM
skanktwo's Avatar
Jus remove the Motor mount! cuz i never had luck with a lil force. wen u take out the motor mount its no problem getting it up there..just have a jack under the motor to help support the other motor mounts
Old Aug 25, 2007 | 12:21 PM
jirro22's Avatar
i dont think you have to remove the motor mount..i have the same headers and i didnt remove the motor mount. i just jack the car on four corners... then i jus work my way going up.dont use excessive force to avoid problems, just find the right angle on how to put that headers thru that space..it will work...
Old Aug 25, 2007 | 03:33 PM
RACER's Avatar
Your car has more than one header
Honda_Lover
Aug 20, 2018 01:34 AM
saxtonsS2k
Feb 23, 2009 06:46 AM
chungtaho0918
Jul 21, 2002 06:57 PM
