Irregular Ride Height
I just bought an '04 and the previous owner installed 18" wheels on it. He had it lowered but put the stock springs back on when I got it. Now, the rear has about a 2 finger gap while the front has a 4 finger gap. Is this normal for a car on 18" rims that is on stock suspension?
the springs look very similar, so he may have reversed the front and rears when he installed it
if you can stick your head down there and check, i know that there are little color marking on each spring, and certain colors should be in the front and some in the rear. i think it was like yellow front and orange rear but i don't remember
Originally Posted by theblackpearl,Feb 22 2010, 01:02 PM
iirc, the front springs are the slightly shorter ones. so if he put the shorter ones in back then the back will be lower (two finger) while the front will be higher (4 finger)
^^ i think you said " the front extremely low and the rear high" but i meant that the front will be higher (4 finger gap) while the rear is lower (2 finger gap) so it is backwards from what you said and it is the problem the op is stating
