Sponsored by: CARiD
J's Differential Distance Collar?
Old Jun 26, 2009 | 12:49 PM
FTW.inc's Avatar
Default J's Differential Distance Collar?
I
Old Jun 27, 2009 | 08:22 AM
jeff_lee_rey's Avatar
Interesting....
Old Jun 27, 2009 | 02:54 PM
S2KPUDDYDAD's Avatar
Shock has one, I helped him via PM and phone calls with the install.
It does help to keep the preload and pinion in place but, a DIY install is not that easy, the collar requires a shim, the shim cost extra. Knowing what shim to buy is the real trick, this is where Shock got into trouble. It took about a month to get it right as I remember also, it took the aid of a local (to him) machine shop to grind the last shim he orderd for a better fit
I use a solid steel sleeve in my builds that is made of 10/20 mandrel (seamless) steel. We custom fit the sleeve (no shim) to the differential.
Old Jun 27, 2009 | 05:43 PM
FTW.inc's Avatar
I think AJ Racing sells the J's with the shims included. what's the process of installing it?
Old Jun 27, 2009 | 07:20 PM
They do not give you a shim kit with the collar, you get "a" shim as far as I know. When Shock did the mod, I think it was $8.00 a shim plus shipping and wait time....
To install it you must take apart the differential and remove the pinion. You will also want to replace the seals and pinion nut at the same time. The rear will have to be cleaned and recalibrated when reassembled. To do this you will need some specialty tools such as, an indicator, (2) torque wrench, plus a few others to make thing a little easier.
I don
Old Jun 29, 2009 | 06:03 PM
GoTuningUnlimited's Avatar
Former Sponsor
The J's Differential Distance Collar do not come with any shims. Correct me if I'm wrong but you should be able to use the OEM Honda shim from the shim kit.
We have these in stock at the moment...
shammo31
Jan 5, 2015 01:49 AM
Sumimasen
Sep 26, 2011 06:49 AM
F22C+K23A
16
Nov 26, 2010 09:14 AM
Sargeant Handbag
Feb 6, 2008 10:12 AM
