Sponsored by: CARiD
just picked up some wheels
Old Jun 23, 2008 | 04:51 PM
qtrung909's Avatar
Default just picked up some wheels
i just picked up a set of mercury silver le-37's. now i need to figure out which lug nuts i should go with. the blue rays, the project kics neo chro, or the muteki neo chro. i think im going to get the extended ones. anybody have any suggestions? only problem i see is that they are 18x7.5 with a 48 offset. i think i'm going to get a 15 or 20 mm spacer in the rear so it'll look a little more aggresive
Old Jun 23, 2008 | 05:00 PM
AusS2000's Avatar
Yeah, without spacers they probably won't even rub!
Old Jun 23, 2008 | 06:30 PM
qtrung909's Avatar
im mon koni with ground controls i want to drop it all the way but the roads in new orleans suck
Old Jun 24, 2008 | 08:01 AM
Voodoo_S2K's Avatar
You plan on putting in extended studs as well to accommodate your huge spacers.
Old Jun 24, 2008 | 10:17 AM
jimbrowski00's Avatar
you could rub if you run a 225 up front...
What size tire are you going to run?
Old Jun 24, 2008 | 04:06 PM
qtrung909's Avatar
225 40 all around. i picked up two 215 35 for the front but i think its a bit too thin.
Old Jul 1, 2008 | 04:38 AM
alphaproject's Avatar
on a 48 you really wouldn't need the spacers my spoons are +45 in the rear and almost rub and the mugens are +59 in the rear
....don't get lightweight lugs if you take your wheels off with any frequency....the rays do strip over time....and if you extend your studs...the rays extended are not for extended studs...only for looks...i would go with an open end style for that
R_Sizzle
Oct 4, 2013 04:52 PM
YLDS2K
20
Mar 22, 2012 10:17 PM
jdmegtim
Jan 27, 2010 02:19 PM
dan_uk
Aug 28, 2009 03:42 PM
