Sponsored by: CARiD
Kics spacer Question
Old May 11, 2009 | 01:52 PM
S2K Driven's Avatar
Default Kics spacer Question
Hey all. Anyone running Kics 15mm spacers on AP2 V3 wheels (08 up)?
Wondering if i would have to cut the stock studs to run the kics spacers with stock wheels.
Old May 11, 2009 | 04:31 PM
Snowmoto125's Avatar
no cutting studs use spacers with built in studs.
Old May 11, 2009 | 04:36 PM
s2k dre's Avatar
No! ur oem wheels have 20mm recessed holes on the back! Im runnin 15mm bolt on spacers too.
Old May 11, 2009 | 04:44 PM
S2K Driven's Avatar
s2k dre are you running stock wheels?
Old May 11, 2009 | 05:08 PM
s2k dre's Avatar
No! but im runnin rpf1's and they have less room than the oems!
Old May 11, 2009 | 06:51 PM
S2K Driven's Avatar
hmm i'll take off my wheel and check for clearance.
Now Do I need a spacer with a ring? Or are the Kics spacers fine the way they are?
Old May 11, 2009 | 07:08 PM
S2K Driven's Avatar
basically. do they need to be hubcentric? I'm finding mixed opinions. Some saying you need to run hubcentric some saying you dont need to. Facts needed please.
Old May 12, 2009 | 05:32 AM
RichV's Avatar
hubcentric is always better, but not a necessity if you tighten your wheels in the air. There may be some slight vibration at higher speeds if the wheel isn't perfectly centered.
Old May 12, 2009 | 10:22 AM
SquirtleS2K's Avatar
Where are you guys sourcing the spacers from?
Old May 12, 2009 | 12:06 PM
adam's2k's Avatar
I heard stories abouot Kicks spacers breaking on track driven cars.
