Sponsored by: CARiD
Knocking after putting on coilovers
Old Mar 17, 2009 | 09:45 AM
phiesope's Avatar
Default Knocking after putting on coilovers
I have been hearing a knock in my rear end the past two days. I installed bc racing coilovers and they work great. Everything is bolted tight. There are no unusual vibrations. When I'm driving usually below 20 mph there is a knock in the rear end and it sounds like a sway bar popping. Sometimes it happens over bumps and sometimes on flat road. It is not a continuous noise, it is sporadic. It sounds like a sway bar that isn't tightened correctly. Is it possible I need to go back and retighten my sway bar? Despite the fact that I did not touch it when I installed the coilovers.
Old Mar 17, 2009 | 09:50 AM
negcamber's Avatar
When you torqued all the suspension bolts, did you compress the suspension or did you just leave the whole car resting on jackstands?
Old Mar 17, 2009 | 10:16 AM
SpooN-FED's Avatar
I had a similar issue with my BC n+ on my old car, i had it replaced under waranty and everything was fine afterwards.
Old Mar 17, 2009 | 05:43 PM
frofro24's Avatar
Go through and check all torques, bushings, and end links/sway bar. Negcamber already touched on it but it is important to preload the suspension before you torque all the bolts.
Or possibly it could be as simple as something in your trunk bouncing around.
markforrester99
Dec 29, 2013 05:29 AM
SlowTeg
Dec 30, 2012 07:52 AM
21k
Oct 19, 2009 12:48 AM
TrackStar
Oct 9, 2007 04:14 AM
amongmany
Feb 7, 2003 03:45 AM
