KW Variant 2 Coilovers
Well, Ive had my coilovers on the car for a couple of days now to "feel" the difference. Ive finally come to the conclusion that something is wrong. My car is very bumpy/rough at low speeds. The smallest dip in a road, that never bothered me when i had the stock suspension on, will make my car feel really bumpy. However, at high speeds its so awesome, It feels really really smooth and i think this is weird. I would assume that feeling a smooth ride in low speeds and a bumpy ride in high speeds should be the way to have it set up. but i don't know because im not knowledgeable in this area. It took me about 5 days of driving for me to be able to put what i felt, into words haha.
So after reading the instructions a last time, i realized that i have no idea what turns are. Can someone explain to me what a click and a turn is? Also, the difference between a click and a turn. (For example: Front Rebound: 1,5 turns open plus or minus 0,25 turns) This is what confused the hell out of me. Can someone explain this to me?
Thanks in advance.
Thanks in advance.
I dont know if the V2s are the same as the V3s but on yours the V2s you can only change the rebound setting on the top I believe.
You turn the top with an allen wrench to change the damping rate. you first turn it all the way clock wise, turn it gently cause theres a point where it doesnt turn anymore you will feel it dont force it or the shock will break.
ok now your on the hardest setting.... now make 1.5 revolutions counter-clock wise or wateva the recommended settings are.
done, you can play around with it to your liking, and if you didnt yet get an alignment done on your car.
rwheelz
Mar 21, 2011 10:14 PM
